Is it possible to insert data into two Excel worksheets using Report Generation Toolkit?
I'm using the toolkit to insert data into two separate worksheets in Excel using named cells. The problem is that it tends to favor one sheet or the other. In other words, one sheet will have data and the other no data and vice versa. (Sometimes I get data in both sheets.) Is there something I can do to clear this up or is what I'm trying to do unreasonable? I would like to use two worksheets so one sheet receives text and data. The other sheet is used to format the data into a printable report. (i.e. using Excel's CONCATENATE function) The second (report) sheet is also used to receive plots (JPEG files) from LabVIEW. I'd send the plot images to the first sheet, but I can
not see a way to automatically transfer images from sheet to sheet. I'm using LV 7.1, Win2000 and Toolkit v.1.0.1
(2,671 Views)
You can use the "Excel Get Worksheet.vi" under All Functions >> Report Generation >> Excel Specific >> Excel General to specify a particular worksheet as the current worksheet. Then, you can specify which worksheet you want to write to in your VI.
Let me know if you have any further questions and good luck!
Kileen C.
NI
(2,671 Views)
