Is it possible to interface MPU6050 Gyroscope/accelerometer module using ELVIS or myDAQ?
Hi, I want to interface MPU6050 Gyroscope/Accelerometr module using ELVIS or MyDAQ. Is it possible to interface? Because MPU6050 has I2C/I/O (SCL/SDA), but in ELVIS or myDAQ there is no such inputs only digital inputs and outputs. So is there any way to interface through digital I/O? If yes, then please guide me how physically i can connect and in Labview.
Thank you.
(3,885 Views)
There are USB devices/chips that can "talk" I³C or SPI.  Use one of them to communicate with your MPU unit.  NI makes one that includes a LabVIEW driver, but I've seen others that "look like" a Serial Device (though very fast) sending SPI commands through VISA.
Bob Schor
(3,874 Views)
Thank you for your kind reply. Yes i know about this but i have to use ELVIS or myDAQ. One of these to interface.
(3,869 Views)
Since your Chip only talks through SPI or I²C, which are special serial protocols that run on fairly fast clock rates that I don't think either the ELVIS nor myDAQ can support, then you are doomed to failure.  You need hardware capable of supporting the protocols that your chip requires ...
Bob Schor
(3,860 Views)
Ok, thank you so much 🙂
(3,856 Views)
