Is it possible to make some FPGA A/D channels differential and some single ended within the same input function?
I am using a PXI-7831 FPGA module and am I trying to scan all 8 A/D channels at once with 4 channels differential and 4 single ended.
(3,227 Views)
as far as I know, you can not. The question is why it would be an advantage to do so? Differential mode is a "superset" of the different IO modes. Using a different mode is usually only necessary, when resources are limited, for example you would have 16 channels in RSE, but on the same HW only 8 channels if in differential mode.
Regards
Stephan A.
(3,227 Views)
Good point. Thanks for the response.
Rob
(3,227 Views)
