Is it possible to match multiple color patterns?
Is it possible to match multiple color patterns like the one shown in Match Multiple Geometric Patterns Example? I'm trying to create a VI similar to Match Multiple Geometric Patterns Example, but the only difference is I'm trying to learn multiple eye (iris) color templates then matching it to an eye.
Thank you!
Edited:
I'm trying to learn multiple templates then matching it to different image.
Message 1 of 8
(7,659 Views)
Please goto
Help>>Find Examples>>Search>>Color>>Color Classification example.
It has multiple color classification.
uday
Message 2 of 8
(7,644 Views)
Hello! I've tried that VI before. What I'm aiming to do is learning multiple (colored) image patterns then matching it to a different image.
Message 3 of 8
(7,641 Views)
You can create multiple template images with different Coloured Images and the do a pattern match and find which coloured Template is Matching with the Original Image.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 4 of 8
(7,607 Views)
@PalanivelT The output image when I'm using the Match Multiple Geometric Patterns is in black and white. How am I going to change it to RGB?
Message 5 of 8
(7,591 Views)
I don't understand why you are using Match Multiple Geometric Patterns for color matching, it doesn't work.
-If you post snippet(https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2PkCAI&l=en-US) or vi it can help.
uday
Message 6 of 8
(7,576 Views)
Not much informative try to post code or VI Snippet.
Initially your question is on Matching colours but now you are mentioning back and White .
Share the code which you have tried and provide us your requirments clearly.
Message 7 of 8
(7,563 Views)
study this link it could help you could no use GM for color match
https://www.ni.com/docs/en-US/bundle/ni-vision-concepts-help/page/color_classification.html
Message 8 of 8
(7,500 Views)
