Is it possible to measure current, resistance, voltage and temperature same time with WSN 3202
Hello Guys
I am new to the LabView
I am trying to measure temperature current voltage and resistance using WSN 3202.
So if I used more than two DAQ Assistant for the reading of Current and Resistance or Voltage get 50103.
I checked the other posting either but I don't think I got it.
So how I can measure all this component using single node WSN 3202
please help...!!
axe
!...aXe...!
(3,288 Views)
The answer is the same as all of the other posts about that error. Use a single DAQ Assistant.
(3,286 Views)
I try to do that but I get same readings for the voltage and current as well..!
!...aXe...!
(3,266 Views)
I'm not sure what you are trying say. If you have physically connected different signals, then perhaps you are not separating them correctly. Attach your code.
(3,251 Views)
