Is it possible to obtain a DAQ acquisition device characteristics - for instance, max sample rate - inside a LabVIEW program?
Hi !!!
I´d like to know if it´s possible to obtain a DAQ acquisition device characteristics - max sample rate, for instance - inside a LabVIEW program. Can anyone help me?
Thanks in advance !!!!
(2,789 Views)
Pass your task to the timing property node and select sampleclock.maxRate for example.  you can get most properties of a device with a similar method.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,781 Views)
In LV 8 and up there is the property browser (under ctrl-shift-B), there you can select the DaqMX object library and search for properties. After finding the right one you can place the node inside your code!
Ton
My LabVIEW Ideas
(2,774 Views)
