Is it possible to obtain a list (string) of all elements within a Global Variable?
I have a Global Variable with many (~100) elements.  I was wondering if it is possible to list all elements and place them into a string array..
to avoid lots of Copy / Paste..  or worse.. typing.
JLV
Message 1 of 47
(4,551 Views)
That's a piece of cake.
The Global is just a VI that has no block diagram.
Open a ref to the VI.
Get a ref to the FP.
Property node to get an array of refs to controls[]
Wire to a For loop and read the Label>>> Text.
You know the rest!
Ben
Message Edited by Ben on 09-27-2006 08:35 AM
Message 2 of 47
(4,546 Views)
Thanks Ben!
Message 3 of 47
(4,538 Views)
I forgot to mention.
All elements within the Global Variable are within Tab Controls..  This is where it got tricky.  I can get the name "Tab Control"..  but it's to get the name of each Tab, then each element within each Tab..
not to complicate things, of course!
Message 4 of 47
(4,527 Views)
That shouldn't be too hard as well:
With some recursion you'll get the idea.
Ton
Message Edited by TonP on 09-27-2006 05:28 PM
My LabVIEW Ideas
Message 5 of 47
(4,521 Views)
Thanks Ton..
That's where I went wrong..  The "ClassName" TabControl..!!!!  ARRRRGGGG!!!!HHHH!!!
I'll try it and post the progress..
Message 6 of 47
(4,516 Views)
Another variation on Tons example would monitor the error cluster coming the the "To More Specific" node after attempting to convert to a "Tab Control" type. If it converted OK, the control was a tab control.
BTW: the approach also helps in scripting if you are trying to find an object of a specific type.
Ben
Message 7 of 47
(4,515 Views)
If I'm right there is somewhere in vi.lib a traverse utility. I'm not sure if it could output all the controls with the naming you want but maybe it's something for you.
Found it:
vi.lib\utitily\traverseref.llb
Ton
My LabVIEW Ideas
Message 8 of 47
(4,510 Views)
Wouldn't "Get All Controls in Container.vi" be wonderful ("Container" could be a front panel, tab control, tab page, cluster, ...).  Has anyone made this that they want to share???
Jaegen
Message 9 of 47
(4,504 Views)
Thanks guys!
It worked very well.
Yes, "Get All Controls in Container.vi" would be wonderful.
RayR
Message 10 of 47
(4,498 Views)
