Is it possible to obtain prescaled voltage?
I'm wondering if it is possible to get the pre-scaled voltage signal numeric value from a channel I am using custom scale units in MAX.
(2,827 Views)
The scale is tied with the Global Virtual Channel you created in MAX.  You should be able to bypass the scale by reading the physical channel.  See the attached diagram.
(2,814 Views)
When I was in MAX, I created an NI-DAQmx Task, not a global virtual channel.  To this task I added all of my signals and applied the appropriate scaling there.  If I have done it this way is there a way to obtain the prescaled voltage?
(2,810 Views)
Reading the physical channel should bypass the task scaling as well.  The diagram I posted is really just creating a task programatically and bypassing MAX all together.
(2,807 Views)
Thanks.  Once I wired in my maximum value (10) and type (RSE), this gave me exactly what I wanted.
(2,800 Views)
