Is it possible to open a LabView VI in a Webbrowser or an HTML-File?
I want to know if it is possible to run a LABVIEW vi (Version 7.0) in a Webbrowser or a HTML-File.
Are there Browser Plugins or other possibilities to create Self - running VI`s ?
(3,046 Views)
LV from Version 6.1 up has the capabilities to support remote panels via a WEB Browser: See the tutorials under
http://zone.ni.com/devzone/learningcenter.nsf/03f7c60f17aad210862567a90054a26c/2ad405a06ebed71586256c4e00621c73?OpenDocument
http://zone.ni.com/devzone/conceptd.nsf/webmain/8BC90A5F744A482886256BA000681713?opendocument
All you need is the LV Runtime Engine installed on the machine where you want to view the running vi.
Additionally you can create standalone running vi's with the LV Application Builder which creates LV executables. These executables are also compatible with the remote panel functionality.
Regards
Stephan A.
(3,046 Views)
Thanks for the help.
Another question for the RemotePanel with the Webserver.
Is there a possibility that more than one person can control the FrontPanel of the same VI at the same time?
(3,046 Views)
the control access to a remote vi is limited to one person at the same time due to safety reasons.
Subsequent requests are queued.
Regards
Stephan A.
(3,046 Views)
Thank you for your Help.
(3,046 Views)
