Is it possible to pair bluetooth device using window API?
Hi, I know that NI labVIEW does not support bluetooth pairing.  Any bluetooth pairing can be done by using other software mean or through Bluetooth Devices icon in the Control Panel.  Is there any way to access these commands from labVIEW (activeX, winsock) or perhap through Window API to pair these bluetooth devices?  I try to pair a usb bluetooth dongle with a bluetooth modem.
BC
(4,451 Views)
Hi BC,
A google search of "programmatic bluetooth pairing" did return some results so that may be a starting point for you.  If you find a Windows dll API for pairing bluetooth devices or an activeX API, obviously you could use this, but I am not aware of anything offhand.
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
(4,435 Views)
Thanks, Doug.  I will give it a try.
(4,405 Views)
This will allow you to programmatically pair with a bluetooth device.
You will also have to download the dotnet files from 32feet
http://32feet.net/files/
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(3,880 Views)
