Is it possible to prepend text to a text file?
Hello folks,
Is it possible to prepend text to the beginning of a text file?  That is, insert text at the beginning of a text file and simply "push" the rest of the contents of the file to a higher offset rather than overwriting the existing data?
Thanks for the help!
Chris
(3,403 Views)
Accepted by topic author chassan
Hi Chris,
no, it isn't...
You can do it the trivial way: read in the old text, prepend the header, write out the full new text...
Or the safe way:
- write header to new file
- read old file (in blocks) and write in append mode to new file
- delete old file
- rename new file to have the name of the original file
Message Edited by GerdW on 07-06-2009 09:43 PM
(3,401 Views)
