Is it possible to read out the zoom factor of a graph
Hi everybody,
I was wondering if there is a function which makes it possible to see what the zoom factor is in a graph?
For example a number that gets higher when I zoom in.
Kenny
(2,892 Views)
There is a "Scale Range Change" event that you can use to get the new scale. There is no "zoom" property per se, like there is with a picture control.
For others: related to this: http://forums.ni.com/t5/LabVIEW/Load-large-txt-file-into-graphic/m-p/1893489
(2,889 Views)
Hi Kenny,
as alternative you can read the scale you start with (x maximum, x minimum), x min and x max are changing when you zoom in. Please notice the attached example.
Martijn S
NI Netherlands
(2,873 Views)
Hi Martijn,
Can you please upload a Labview 10 version of the vi, I'm still using Labview 10.
Kenny
(2,869 Views)
Hi Kenny,
here you are,
best regards,
Martijn S
NI Netherlands
(2,867 Views)
