Is it possible to read the peak-to-peak TKTDS1K2K driver directly?
Thank you for your quick response
I want to check peak-to-peak to control volts/meter.
If I get the NaN value then I can reduce the Volts/meter value until I get a number value , then I can display whole wave form.
If I display whole wave form it will take more than 7 seconds per value.
If you have any aternative , please answer to me.
thank you
regards
pathman
Message 11 of 14
(614 Views)
Hi
I don't know some where server feil , I couldn't send the message, But I repeated many times. Sorry for this inconvenient ...
thank you
Message 12 of 14
(614 Views)
Hi
thank you
Message 13 of 14
(614 Views)
So you would get the "?" when there's no waveform? I haven't used the instrument in a long time and I don't have a manual. It might be possible to read the status byte of the instrument to see if acquisition is complete and then do the transfer.
Message 14 of 14
(614 Views)
