Is it possible to reset the data (as default value) at XNET READ output?
Context: I am working on project on which I have several devices with the same LIN address. I am communicating with them using a driven multiplexer to talk with them one after the other.
For this, I put the drive of the multiplexer and the writing+reading of LIN Frame in a loop.
It works pretty well except that when I remove on purpose a device, the output of XNET READ keeps the previous value (from the previous sensor in the sequence) and I cannot detect that there is a missing device.
Is there a way to reset the XNET READ output value to its default value (only zeros) ?
Note 1: I first used XNET signal single point and now Frame LIN but both ways do not reset value.
Edit: As on XNET READ (signal single-point) help, it says that data content is default value if no frame has been received since I have started the session, I have put a start and stop session into each loop, but it does not reset the XNET READ output value...
Thank you advance,,
(1,258 Views)
Accepted by topic author TeraEngineer
Just to bring some news for ones who'd be interested:
  • I didn't find a way to reset the default value
  • But I have made a timestamp check thanks to the use of Read "Signal XY" function: if timestamp of last Read function is the same as the previous one, it means that nothing new has been received, and I don't use this data.
I guess that even-trigger "mode" could also be used.
(1,212 Views)
