Is it possible to run a labview executable on Android/Windows tablet which can control USB-6210 DAQ?
I was wondering if anyone has had any success running a labview executable on an android/windows tablet?  I would ultimately like to control 1 or 2 USB DAQs.
(4,010 Views)
For a Windows tablet, assuming that the hardware is x86-based, you're just running normal Windows so controlling a DAQ should be the same as it would be on a desktop or laptop machine. Assuming that the tablet has a spare USB port, of course.
For Android, I don't think there's any easy way to directly control a DAQ; you could host the DAQ on a computer and have some sort of web-based front end on the tablet to relay commands and get data back.
(3,992 Views)
Given the tablet is x86 based and runs Windows (not the RT thingy, the real one) it has a possibility of being able to do it. However the USB-ports might be low on power for the DAQs, so it is something you should try to test before buying.
__________________
Engage! using LV2015
(3,981 Views)
