Is it possible to set the Port used by Labivew on Windows
I everybody,
I am trying to connect a Labview GUI to a Raspberry Pi / Python code  as described here : http://etchingpathways.blogspot.ch/2013/09/labview-and-raspberry-pi-tcpip.html
However it appears that the Port used by Labview on my Windows computer change everytime I run it... And I need to specify this Port in the python script to make the connection between the two devices...
Is there a way to set the port used by Labview ?
Cheers,
EDIT :
Hum Sorry I misunderstood something the connection works... I thought I had to specify the Port used by the software Labview in Python and not the port specify in the GUI....
(3,100 Views)
