Is it possible to set the windows o/s system clock with a labview 8.5 program?
I am interested in setting the windows o/s system clock from within a 8.5 labview program, is this possible?
(3,192 Views)
Accepted by topic author Yun2
If you are on windows the command time will allow you to set the time. You can use system exec in labView to do this. For more information on the command:
http://www.wikihow.com/Change-the-Computer-Time-and-Date-Using-the-Command-Prompt
Message Edited by Pawel Kowalski on 03-02-2009 02:44 PM
(3,191 Views)
