Is it possible to use PC Card flash disks on PXI-8221 when using real-time OS?
Hi. We will build an application to run on a RT PXI controller. We would like to use an additional removable flash disk, so we thougth about using the PXI-8221 PC Card carrier and a PCMCIA flash disk. Is this possible on real-time?
Daniel Ramírez
MSc - Mechanical Engineer
Universidad de Concepción
(2,645 Views)
Hi, Daniel,
Currently, the PXI-8221 is not supported under LabVIEW RT. If you need to have an external hard disk for additional disk space, I will recommend you getting a PXI-8252. This is a FireWire card and you can connect an external hard drive to it with the right HDD enclosure.
Let me know if you have any questions.
GValdes
(2,635 Views)
