Is it possible to use an IrDA protocol with LabVIEW 8.2.1 in DSP BlackFin?
Dears,
     I'm building a project to communicate a DSP BlackFin 533 with a Palm E2 Tungsten between IrDA Protocol. The packaged LabVIEW installed in Palm allows to use IrDA protocol, but I don't know if the packaged for BlackFin DSP allows or not.
Renato - RPS
(2,836 Views)
Hi Renato,
To enable Windows Mobile 5.0 devices, for example, to trasmit data using IrDA, the serial port must be converted to an IrDA port. This can be accomplished by getting a handle to the serial port and passing it to the EscapeCommFunction DLL. This will allow the resource to be used to transmit IrDA. Follow the example in the code below when creating applications that transmit data using IrDA.
Filipe Silva
Application Enginnering
(2,794 Views)
OpPss ...
Sorry !!!
(2,791 Views)
