Is it possible to write VIs format from outside Labview ?
so, is the VI format is know and public, that it can be written by an(/my) external tool ?
Nicolas
Message 1 of 11
(4,339 Views)
No. The VI file are only editable with LabVIEW.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 11
(4,332 Views)
No, the format is private, and the tech support folks sing praises every day for this, no doubt.
It has changed between versions no doubt ("This VI has a newer version than LabVIEW") and will change again.
You can make a tool that will script LabVIEW to create a VI, though.
Steve Bird
Culverson.com
LinkedIn
Message 3 of 11
(4,324 Views)
Steve described it well.
Writing LV code outside LabVIEW would be an enourmous challenge, if at all possible.
You can use LabVIEW to generate LabVIEW code, but that would not be an external tool..
so the easy answer is no.
Message 4 of 11
(4,313 Views)
OK it's impossible wihtout LV.
Message 5 of 11
(4,271 Views)
Out of curiosity, what are you trying to accomplish?
Message 6 of 11
(4,242 Views)
I think it will be interesting to write a processor that interpret G Code.
Nicolas
Message 7 of 11
(4,213 Views)
For what purpose? Are you trying to make a LabVIEW alternative? I'm confused as to what you're trying to accomplish.
Message 8 of 11
(4,195 Views)
In fact, I think LabView language adresses the massively parallel CPU programmation problem (for CPU with many cores).
And thus can be used to compile for low-level code (like the LV G-Code to FPGA Module for example)
Your position ?
Message 9 of 11
(4,178 Views)
"Interesting" it will certainly be.
Steve Bird
Culverson.com
LinkedIn
Message 10 of 11
(4,166 Views)
