Is it possible to write the instrument IO commands all in one step
I am using the instrument IO assistant and was wondering if I had to keep adding a write step for each command I wish to send or if I can place multiple commands within a single write step.
(3,137 Views)
That depends on the instrument. If it's a SCPI instrument you can use semicolons to separate multiple commands. So in your "Write" step, for the command to enter, enter the list of commands separated by a semicolon. You'll need to confirm this with the instrument that you're using.
(3,127 Views)
Hi Edmile,
As the previous poster stated, depending on your device, you may or may not be able to write multiple commands within a single write step.
What kind of device are you sending commands to?
Please let us know if this helps.
Christian A
(3,097 Views)
