Is my project overengineered? (baseband encoding)
Hello, I have a VI for manchester and nrz-m baseband encoding using an analog input/output, but I feel that I've made it a bit more complicated than it should be. Is there a way i can achieve this in a more simple manner? I'm not asking for a whole functional VI (although it would be welcome), I want to know which method and VI's I should use to make it simpler.
In the attached VI I'm first converting the analog signal to digital and then to a bool array (I was using a bool array as an input in an older version) and doing the actual encoding on said array. But it doesn't feel like an optimal solution.
Any ideas?
Message 1 of 1
(750 Views)
