Is new NI-Daqmx for LabVIEW 2009 needed
Hi
Now that there is LabVIEW 2009 will there be NI DAQmx say 2009 also. Because during NI DAQmx installation, you have to specify the type of LabVIEW support to install with the driver or must the NI DAQmx driver just have to be re-install after installing the new LabVIEW 2009 and select LabVIEW 2009 support .
I had a problem downloading the trial versions, unlike the previous versions which there are 2 download files (small and big files), LabvIEW 2009 just have one big file for 32 bits (755 M bytes) and if the download is complete, the downloaded file size is now the smaller and if u have to run it , there is a small dialogue box to choose to hide or to pause or cancel, and after choosing your option, it disappears. And if u try to delete the downloaded file, it display a message that it running and another program is using the file. If you end it using task manager and try again to delete the file it still display the same message.
I don't know if i'm downloading correctly, i'm using windows 2000.
Rgds
Paul
(4,741 Views)
Hi Paul,
after installing a new LabVIEW version you have to install the drivers again to get the LabVIEW support. It's independent from a new DAQmx version.
Mike
(4,734 Views)
see here
(4,723 Views)
(4,693 Views)
The knowkedge base article is also there in the link mentioned by mathan.
(4,692 Views)
Hi Guys
Thanks for all the supports.
Rgds
Paul
(4,662 Views)
