Is the 'Available Embeddded Ram' on the 78x1R manual correct?
I am currently using a 7831R. The manual lists on page A-6 that the available embedded ram is 81,920 bytes. However, when trying to access the ram (and according the the help on the memory read/write functions) the available ram is only 16k = 8192 * 2 bytes. Is there really 81,920 bytes available and I'm just doing something wrong? Or is this a typo in the manual?
Thank!
Rigo
(2,561 Views)
The 7831R ships with 16KB available RAM. The manual (page A-6) states the available embedded RAM is 81920 bytes. This is possible by using the Memory extension utility for LabVIEW FPGA. The following link has a tutorial that explains the Memory extension utility and you can also download the utility for your version of LabVIEW FPGA.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=BE211EB859136066E034080020E74861&p_node=200449&p_source=External
(2,549 Views)
Thanks a lot!
(2,544 Views)
