Is the Cursor.cursor info property from 5.1.1 supported in 6.1?
I have compiled a 5.1.1 application to 6.1 and see that the wfm graph property Cursor.Cursor Info cluster is present and wired. When I create a new waveform graph in 6.1 I can't find this property. Is it still supported?
(2,715 Views)
The cursor properties from 5.1 are still there (plus a few more), just not bundled into a cluster CursorInfo. For example, CursorInfo.Cursorname is now just Cursor.CursorName
If you need them bundled as a cluster, for compatability or convenience, you'll have to bundle the individual properties into a cluster.
If you're working within the same VI, you can copy the property node (using +drag) then right click and select "Link to" and you'll be able to reassign this property node to a new graph.
Tim
(2,715 Views)
Tim, thanks for the reassign tip. It appears to work and will save me the effort of unbundling my existing cursor properties.
Looks like I'll need to take a deeper dive into some of the 6.1 enhancements!
~Pete
(2,715 Views)
