Is the GPIB Write "data" parameter and the VISA Write "write buffer" parameter the exact same thing?
hi,
I am new to labview environment. I wud like to knw whether the GPIB Write "data" parameter and the VISA Write "write buffer" parameter the exactly same thingor not..If not then how can i convert "data" parameter into "write buffer" parameter? Kindly respond to this problem.
(2,508 Views)
Hi sb88,
yes, they are the same. Both functions will send the data wired to their "data"/"write buffer" unput to connected HW device...
Why didn't you simply tried this with a small VI?
(2,506 Views)
