Is the maximum input voltage rating for daq 6009 +- 10V per channel or per whole device ?
I am a beginner user of LabView and DAQ6009. I have two sensors that supply 0-8V as two analog inputs for my daq 6009. Can I supply -10<V<10 to each analog input channel of my daq or is the +-10volts the overall limit for all analog input channels.
Awais
(2,739 Views)
that would be for per channel
Guru
Regards
Guru (CLA)
(2,730 Views)
The +/- 10 volt is for each channel. But on the other hand the sample rate is must be shared on all input channels. The max sample rate given in the data sheet is for one channel. So if  use two channels the you can only use half the samplerate and so on.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,729 Views)
Yep.. As they mentionned, it is per channel.
(2,710 Views)
