Is the registry key "NI-VISA FOR WINDOWS 95/NT" a reliable way to detect if NI-VISA is installed?
Is the registry key "HKEY_LOCAL_MACHINE\SOFTWARE\NATIONAL INSTRUMENTS\NI-VISA FOR WINDOWS 95/NT" still a reliable way to detect whether NI-VISA is installed on a computer?
There was a thread from 2002 in which this was referred to:
I didn't find anything more recent.
Jim
(3,155 Views)
Hi Jim,
I haven't used the registry key but I think a sure fire way is to perform any VISA operation such as VISA Find Resource and if you get error code -1073807202, then VISA isn't installed.
Dennis
(3,150 Views)
I guess I should have mentioned that this is for an installer developed in Installshield.  There will be no LabVIEW code running.
The installer is checking to see whether NI-VISA is installed on the Computer.  The installer is also verifying the version.
We would like to detect whether NI-VISA, Agilent VISA or both are installed on the computer.
There are three valid configurations:
  • NI-VISA only
  • Agilent VISA only
  • NI-VISA primary with Agilent VISA secondary
If you install NI-VISA when Agilent VISA is already installed as primary, it will corrupt the Agilent VISA.  The NI-VISA installer doesn't check for the presence of Agilent VISA.  NI doesn't support running as the secondary VISA.  Notably, Agilent will install as a secondary VISA.
If Agilent VISA and NI VISA are installed, then you need to check to see if Agilent is secondary and whether the NI-VISA Tulip setting is on.  To properly install this case, you must uninstall Agilent IO, install NI-VISA, then reinstall Agilent IO.
Our next version of the installer will detect the three configurations and do the 'right' thing.
Jim
(3,140 Views)
Hi Jim,
The Registry key is still valid, so you should be able to use that for your check. Thanks!
Ebele O.
(3,111 Views)
