‎08-21-2003 08:43 AM
‎08-21-2003 08:53 AM
‎08-22-2003 04:09 AM
‎08-22-2003 06:59 AM
No such thing as "too many CASE" statements. Don't worry about it. If you're running out of room on the diagram, then use a sequence to put things in separate frames, or use subVIs to put things into separate VIs.
If your choice is to write something or not write something, then you have to use a CASE. The SELECT option will let you write THIS, or write THAT, but you have to write something (even if it's empty).
