08-16-2010 02:30 AM
I know for Labview there is version for Mac or Linux.
Just want to learn if there is DAQ driver for MAC or Linux, which can support USB DAQ.
Thanks.
Solved! Go to Solution.
08-16-2010 07:34 AM
Alex,
I do not know about Linux but DAQmx Base is available for the Mac. You would need to check the documentation to see which devices are supported. Some are while others are not.
Lynn
08-16-2010 08:55 AM
Hi Alex,
Lynn is correct. For using NI's USB DAQ hardware with Mac and Linux, the best and only driver to use is NI-DAQmx Base. The readme file lists what specific devices are supported, which specific Linux and OS X versions are supported, and which hardware features are supported.
[1] NI-DAQmx Base 3.4 for Linux
http://joule.ni.com/nidu/cds/view/p/id/2128/lang/en
[2] NI-DAQmx Base 3.4 for Mac OS X
http://joule.ni.com/nidu/cds/view/p/id/2127/lang/en
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
