Is there Instrument I/O Assistant version that compatible with Labview 7.1?
I was download Labview version 7.1 and Traditional NI-DAQ (Legacy) Version 6.9.2 and Instrument I/O Assistant Version 1.0.1 all for windos XP, but when I try to use DAQ Assistant Express VI on the input palette, this message appeare '' your installtion of Instrument I/O Assistant is incomplete because you must install Labview 7.0 before installing Instrument I/O Assistant '', so I want version of Instrument I/O Assistant that compatible with Labview 7.1  or help me how to avoid this problem and let me use my Hardware (PCI-6023E) by the program Labview 7.1 please help me.
(2,773 Views)
Rammo,
i am not sure what you have done, but there are several points we have to clear up (terminology and licensing):
a) LabVIEW 7.1 is no downloadable version if you like to have a legal license.
b) Traditional DAQ does not support the NI DAQ Assistant (which is different to the Instrument I/O Assistent).
c) If you like to use an assistant which works with the PCI-6023E, you have to use the DAQ Assistant.
d) The DAQ Assistant is included in NI-DAQmx, which is included in every NI-DAQ-Version since 7.0. In fact, since DAQ 7.5, DAQ includes only DAQmx.
e) The Instrument I/O Assistant (which is for communication with external instruments such as scopes or different interfaces as serial) is included in NI-VISA.
I hope this list will clear things up a bit.
Now to a way to solve the issue:
- make sure that your LabVIEW is a legal version. if you downloaded something from our webpage, it should be LV 7.1.1. this is an update to 7.1 only! (it does not fit to 7.0)
- install NI-DAQ 7.0 or newer (i would advise 7.4 or newer) on the PC for the DAQ assistant.
- best install NI-VISA as well. you can dowload VISA from our webpage, the newest version is at the momemt 3.3.1. then you can use the instrument I/O assistant as well, but not for the PCI-6023E!
- install all drivers (DAQ, VISA) AFTER you installed LabVIEW!
Norbert B.
NI Germany
Norbert
Expert: Geometry
(2,760 Views)
