Is there Omicron module that allows to monitor its own outputs?
I'm trying to check some measurement issues between a Relay and the Omicron.  Is there a way to moniter the Omicron directly at the outputs?
(2,682 Views)
Hi Mux,
Can you be more specific about what NI HW and SW you are using, and what it is exactly that you are trying to do?
Thanks!
(2,669 Views)
Been a while since your post- hope you resolved the issue.
Per your post, I suspect you're using a CMC-256 Relay test set??
Are you handling the Omicron through LabView? where did you get drivers?
Anyone?
(2,566 Views)
