Is there a LabVIEW function that will pop-up a dialog box to prompt the user if he is sure he wants to do when a boolean switch is pressed?
I want to prompt the user by asking, "Are you sure you want to do this?" when the user presses a switch.  If the user clicks "Yes" then the switch changes state, if the user clicks "No" then the switch retains the current state.  Does such a thing exist or do I have to invent it?  I am new to LabVIEW.
Thanks.
(3,113 Views)
Look under the Time and Dialog Functions for one and two button dialogs. Use appropiate logic and flow for your application for the yes and no responses
(3,105 Views)
You can use an event structures filter event on mouse down for something like this.  Pop up a dialog and invert the logic for the output and sent it to the Discard? modifier on the right side.  See example for assistance.
(3,100 Views)
Chaos,
I appreciate the help.  I think that will get me where I want to go.  I am taking a labview class next week, so hopefully I won't have any more dumb questions, but I have one now.  How do you add the discard modifier in an event case.  Even when I duplicated the case for another boolean, the modifiers all turned white and I can't figure out how to fix them.  Thanks again for the help.
MA
(3,088 Views)
The other question I have is how do make it give a boolean output?  I need it to give a true or false depending on the state of the button/indicator.
(3,074 Views)
