Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Is there a NaN constant in 6.1?
Matthew_William
s
Active Participant
10-06-2003
10:47 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I found Not a Refnum/Path, etc. but there does not seem to be a NaN constant on the toolset. Using sqrt(-1) for now.
1
Kudo
Message
1
of 4
(6,586 Views)
Reply
Re: Is there a NaN constant in 6.1?
LucaP.
Active Participant
10-06-2003
10:53 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Matthew
Place a numeric constant on the block diagram and type NaN inside.
Luca
Luca
4
Kudos
Message
2
of 4
(6,586 Views)
Reply
Mads
Active Participant
10-06-2003
10:54 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Just drop a numeric constant on the diagram and write NaN in it...it will change to a NaN constant.
Mads
Mads Toppe
Check out our Modbus Test Master - developed in LabVIEW
0
Kudos
Message
3
of 4
(6,586 Views)
Reply
Matthew_William
s
Active Participant
Author
10-06-2003
11:38 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks. Guess that was a little too obvious for me. Works great.
Matt
0
Kudos
Message
4
of 4
(6,586 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
