Is there a VI for controlling the integration time of a Keithley 2000?
Dear All,
I want to do some voltage noise measurements using a Keithley 2000, by taking a fixed number of data at different integration times of the A/D converter (different rates). Can you kindly tell me if there is a VI, which would do this for me or which subVI would be needed for construction of a VI that would carry out the task. Thank you and I look forward to hearing your suggestion.
(2,648 Views)
If you are measuring DC, I found the VI "Ke2000 Configure DC Volts.vi" in the instr.lib.  On the vi you can set the # of Power Line Cycles(integration time).
To search for the instr.lib for the Keithley 2000 (if using LabVIEW 8.2), on the front panel select Tools>Instrumentation>Find Instrument Drivers.
NI has many instrument drivers, if you search there and cant find what you need,  then I would go to the programming manual for the instrument and write my own driver.
Brian
Brian
(2,606 Views)
