Is there a VI in LabView that deals with Bivariate or Multivariate normal probability distributions?
Hey all,
I was just wondering if there was a VI that would do what the Continuous PDF does, but for 3 dimensions. So intead of just having X and Y values as outputs, a third dimension would be incorporated. I'm trying to apply a probablity function to a binary image (converted into a matrix) and just thought that LabView might have some easy way to do this for me.
Basically, instead of getting something like this:
I would get something more like this:
Phil
(2,516 Views)
Hi Philark,
There is a set of tools that allow you to plot 3D curves and meshs. Its found on the control palette under Modern >> Graph. I have also attached a quick example of how to feed your data into the graph and display it on your front panel.
Let me know if you have any questions!
Cheers,
Jonah
Jonah Paul
Marketing Manager, NI Software
(2,497 Views)
