Is there a VI which reads audio signals off optical SPDIF port?
I am trying to capture audio signals from a DAT unit on to the computer's hard drive. Could you please tell me how can I read these signals off an optical SPDIF port using Labview and save the streamed data as a wav file? I am using an audio capturing interface called the Edirol UA-5 to transfer the audio signals from the DAT unit to the Mac's hard drive.
Bhuvana
(2,919 Views)
Hi Bhuvana,
There are not any VIs in LabVIEW designed specifically for SPDIF.  There is, however, a tutorial on reading an SPDIF signal using LabVIEW FPGA.  You may also be interested in this thread which discusses the use of a digital data acquisition board and the rate needed to read an SPDIF signal.
Jennifer R.
(2,849 Views)
