Is there a better way to Rename XYZ Graph Axes?
I have two XYZ graphs that I rename the XY and Z axes based on the data that is being shown on the graph using the code shown below.Capture.PNG
Although it works, I can't help but think there has to be a better way. If anyone has a solution please let me know.
(3,422 Views)
Hello GentlemanS,
You can do the same with a for loop wit 3 itérations. It'll avoid code duplication.
Regards
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(3,403 Views)
Another thing to emphesize: if you use often Flat Sequence structures in your codes, then you are likely doing wrong. Whenever I see codes with Flat Sequence Structures, 99% of the times it is a strong sign of a bad coding style (1% of the codes have a valid usage case of sequence structures, like benchmarking, etc...). Think of data flow, and whenever it is possible use error wires to determine execution order.
This is a good read to have a look:
http://www.ni.com/newsletter/51735/en/
(3,393 Views)
@sabri.jatlaoui wrote:
Hello @JScherer
Regards
Nice! The bundle array.vi does accept references
(3,363 Views)
