Is there a better way to build these arrays?
I am using Labview 2014 but it shouldn't matter for my question.
I am using a Labjack to monitor 20 digital inputs.  This is a common type of test setup for us.
Is there a better way to build these arrays to save space?
In the process of thinking about this question, the second pic occurred to me.
I haven't tested it yet, but thought there has to be a better way than what I have been doing.
Message 1 of 9
(3,869 Views)
Accepted by topic author RedneckNerd
For the first one, just wire out the iteration terminal directly, forget the shift register.
For the second one, use the "Initialize array" primitive to create a 20 length array with the same value.
Message 2 of 9
(3,863 Views)
And in both cases, remove the "build array" after the loop. Since both array are of the same size, a single FOR loop is all you need.
Depending on the desired representation of the blue array, insert a conversion bullet before the output tunnel.
Message 3 of 9
(3,849 Views)
Thank you.   Exactly what I was looking for.  I vaguely remember initialize array from class a couple of years ago!
I also found with my application I have to get rid of the build array.  As it creates a 2d array and I need a 1d array.
Message 4 of 9
(3,846 Views)
Amazing the how I can miss the Forrest for the trees.
Message 5 of 9
(3,830 Views)
Build both arrays in the same loop.  Fewer functions on the BD.
aputman
Message 6 of 9
(3,829 Views)
Just wanted to point out that your shift register usage is probably not what you wanted (it'll produce an array with a single element). The answer above is good, but in the event that you want to save even more space, you can create a subvi for the top build array example. This is commonly called a range function such as in python (https://docs.python.org/3/library/functions.html#func-range). Matlab has someone likewise built in as a primitive (https://www.mathworks.com/help/matlab/ref/colon.html?searchHighlight=colon%20operator&s_tid=doc_srch...) as do many languages (especially vector heavy languages such as R). It's not clear to me that basic labview has this function built-in so it isn't a bad idea to build it yourself.
Message 7 of 9
(3,819 Views)
For building a sequence of numbers, you can use the Ramp Pattern function.
Message 8 of 9
(3,815 Views)
Useful for creating orange ramps. Overkill for integers 😄
Message 9 of 9
(3,780 Views)
