Is there a connector on the _SQLCIN that allows you to set a connection timeout?
If not then could anyone suggest a way around this, maybe in the SQL server set-up or ODBC?
(2,538 Views)
Phil,
In the SQL toolkit you have the following vi's :
Set Login Timeout; Get Login Timeout
Set Query Timeout; Get Query Timeout
These are under the configuration palette of the SQL toolkit.
Jared
(2,538 Views)
