Is there a dynamic delay for feedback z nodes?
It seems the delay on the feedback node can only be hard coded. Is there a dynamic way to set the delay?
(3,298 Views)
No there is not. The feedback node allocates room for all the data at compile time, so it must know then how large the delay is.
For a dynamic buffer size, you might search the forums or web for a LabVIEW circular buffer example, of which there should be many.
Jarrod S.
(3,291 Views)
I am actually already using a circular buffer. I developed that before I knew about the delayed feedback node. I wanted to do a performance comparison between the two but I need it to be dynamic either way.
(3,273 Views)
