Is there a function to convert a parallel signal into a serial?
What I want to implement is to make 9 bit 100ns (10 MHz) 9 parallel digital signals into approximately 10ns (100 MHz) 9 bit 1 serial digital signal.
Is it possible to implement it with Ni-HSDIO and PXI-6544?
In other words, I would like to combine 9 parallel signals into 1 serial signal.
I've looked up a lot of things at the moment and I think I need to use a function called niHSDIO-ConfidentureSerializer, is that correct?
I can't see that function in the Ni palette and examples right now, is there any data or method that I can refer to?
Or is there a function to convert a parallel signal into a serial?
Thank you so much.
Message 1 of 1
(445 Views)
