Is there a function to find the peaks in a 2D-map?
Hello everyone I have a 2Dmap,and in the map there are many peaks,like the picture below: Is there a function to find the peaks in the map? There is a function to find the peaks in a 1D array,Peak Detector.Is there a function just like this for 2D arrays? Thanks
(3,052 Views)
No specific function in LV.
If you have Imaq Vision, you should use the watershed function to define the area where a peak occurs. Then finding the max coordinates would be easy.
Chilly Charly    (aka CC)
(3,012 Views)
