Is there a function to have a graph with both the full signal and a zoomed in signal displayed?
See the Jpeg attached. Ive created this using 2 seperate graphs. Ideally Id like to do it using a single graph. Is this possible?
(2,647 Views)
Accepted by topic author scottcolston
If you plot the same data as two seperate plots
AND
You create two seperate X and Y Scales
AND
You associate one plot with each scale pair of of XY scales.
Then you will be able to change the range of one set of scales to achieve an effect similar to zooming in on one.
Ben
(2,636 Views)
