Is there a list of specifically what is and is no tested on the PXI-6259 when self-test is run under MAX?
Is there a list of specifically what is and is not tested on the PXI-6259 when self-test is run under MAX?
(2,669 Views)
Self test doesn't do all that much...  It is a check to make sure the driver can communicate with the hardware.
I'm not sure what you're hoping to test for, but you might want to take a look at the DAQ Diagnostic Utility if you're trying to diagnose damaged or defective hardware.
Best Regards,
John Passiak
(2,645 Views)
I was hoping for an automated go-no-go test that verifies all functionality of the Card or at least a list of what actually is functional after passing the test.
(2,632 Views)
So exactly the DAQ Diagnostic Utility?  The tests done are described in the readme.
Best Regards,
John Passiak
(2,592 Views)
