Is there a peak picking vi in labview examples?
Hi
I was wondering if anybody has come across a peak picking vi in labview examples.
I have a 1d array of spectral data that I would like to run through a routine which detects the peak positions and gives there height from the base line.
I seem to recall seeing some peak picking routine in Labview before, which does something like this and alllows you to set a peak threshold so you can reject low intensity peaks.
I hope somebody can point me in the right direction.
Many thanks
Ash
(2,754 Views)
Ok, I've found it.
Go to analysis directory in examples and look in the peakxmpl library
(2,750 Views)
