Is there a programmatical equivalent to Export Simplified Image?
Doing what is in the image programmatically?
R
Message Edited by JoeLabView on 10-07-2008 01:36 PM
(3,470 Views)
Use the Invoke node "Export Image" to do programatically.
Raja
Message Edited by Rajaa on 10-07-2008 12:50 PM
(3,461 Views)
Thanks Raja,
I forgot to mention that is it using LabVIEW 7.1.  I didn't see that feature in the Invoke Node.
R
(3,439 Views)
Accepted by topic author Ray.R
As far as I know, for LabVIEW 7.1 the only way to do it is to use the Get Image method with the bit depth set to 1 (for monochrome), and then use the Write BMP File function.
(3,425 Views)
Thanks Saverio,
I knew about the Get Image method, but I never thought of the but depth set to 1 for monochrome.   You must have read my mind about this one because it's another detail I had omitted.. 😮
This is exactly what I was looking for.
Thanks!
R
(3,413 Views)
