Is there a recently updated vi for automatically creating a typedef in LV from a JSON?
I used a "JSON to LabVIEW cluster" vi I found on the forums here some time ago, but had to do some programmatic cleanup on a particular JSON before it could be pushed into a LabVIEW control via "Unflatten from JSON.vi".
I just went to use this vi again with another JSON structure and am having to go through the whole process again of figuring out what part of the JSON LV does not like.  The JSON passes through every JSON checker I find online.
It looks like LV can't handle nameless items and null data.  I have to add names, and have just been putting the null in quotes so it can cast it.
What is the best method to go through this process?  is there no better way other than inserting names?
edit: this is the vi I'm referring to.  I'm certainly grateful for it, as it beats having to do this manually...
Message 1 of 1
(1,107 Views)
