Could you post a sample of the code that demonstrates the issue? Are you applying weighting (A-weighting would apply a relative response of -70 dB at 10 Hz) to the signal when you do octave analysis?
When I input a 10 Hz tone from a function generator to to AI0 of a 4472, I get consistent results between the power spectrum and 1/n octave (see attached results).
Another thought, how did you implement 1/3 octave analysis? The 1/3 octave analysis VIs take an enum for the low frequency where the lowest frequency in the enum is 20 Hz. I had to use the 1/n octave VI which takes a DBL for the start frequency.
Hopefully, some of this rambling helps,
Doug
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
