Is there a simple VI for PI control of DC motor using labVIEW?
I am trying to control DC motor position using PI algorithm. I have succeeded in achieving using proportional control, but I need to fine tune it using PI control. I am using one analog input channel which gives the DC motor's current position, and counter output whose frequency and duty cycle control the DC motor. I am working with PXI6251 card. Can you help me with a VI for PI control?
(3,535 Views)
Why don't yuu use the NI labVIEW PID control toolkit?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019RTlSAM&l=en-US
Message Edited by kikiduu on 12-26-2008 01:45 AM
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(3,532 Views)
I am not able to open the link. Do I have to pay for the toolkit?
(3,519 Views)
This is the correct link.
This toolkit comes as part of NI Developer Suite. Also you can buy this toolkit separately.
Message Edited by kikiduu on 12-26-2008 03:45 AM
(3,514 Views)
If you can't spend the money on the PID toolkit then you will need to spin your own. Information and links can be found in this post. You can also take a look at the Simple PID Demo. Can't really say anything about this example as I've never used it. I simply did a search (amazing tool these days).
(3,492 Views)
